DIY Very Big Bang | Page 4 | on ElectriciansForums
Discuss DIY Very Big Bang in the UK Electrical Forum area at ElectriciansForums.net
Ricard
London
I am not a professional electrician and am posting this partly for your general amusement and partly to get some background advice.
My son who has recently moved into a rented flat in Nottingham having got his first job there, decided to put up some coat hooks. He seems to have taken insufficient notice of the fact that the consumer unit is above where he was drilling. Apparently there was a very big bang and the hole shown in the picture appeared without any further exploration on his part.
He phoned me for advice and sent me the pictures, mentioning that none of the fuses seemed to have blown and everything is still working. I explained that the reason no breakers had tripped was that these are the main cables coming into his consumer unit and therefore before his breakers. I am a bit surprised that the company fuse didn't blow, but I guess it must have been a very short bang.
My advice was call your landlord's agent, you need an electrician because there is no way you should attempt to do anything with this.
The consumer unit is near the ceiling on the opposite side of the wall to the meter cupboard.
My questions are first will there be any way to fix this other than digging out the cables and replacing them from the meter to the consumer unit.
Secondly to ward against the agent inflating the cost, what sort of ball park cost should it be.
Finally, is it appropriate for the main cables to be buried in the wall without any protection (from idiots).
  • [ElectriciansForums.net] DIY Very Big Bang
I know , not to pretty though. ;)
PS. It just goes to show though that safe zones are not publicised enough.
That could have had a nasty outcome.
can't see the problem with the isolator. the actual isolator body is about 2". or even fit a KMF. they are designed for in at bottom, out at top.
Depends on what the landlord would be happy with.
If I was paying the bill , I would be happy. :)
The landlord might not want some ugly trunking going up his wall. The cable was initially in the wall and he may want it that way again.
@Ricard Has the landlord been told yet? If so then what has he said?
The cable was buried when burying cables like this was loosely acceptable
Putting it back exactly like this even if this was acceptable 10 years back would now not meet regulations
The cables need to either be on a 30ma rcd now or installed in earth metal containment
Trunking all be it a bit ugly will probably be best solution
I think you misunderstand me mate. What I was implying is that the landlord may want the cable back in the wall, so it's not visible. Of course this would have to be done to the regs. I thought that that was obvious and didn't need stating..... It seems it did.
All speculation at the end of the day.
Still waiting to see what the landlord has actually said about the situation.
If the landlord has any sense this should be his preferred option as it would prevent it happening again
True, but then you could say that about all cables in walls.
A certain amount of common sense had to be used when drilling into walls and big electric boxes are on said wall 12 inches away...
Not sure how feasible but how about coming up the exterior in SWA glanded into suitably rated IP65 JB then straigt through into the back of the CU with tails.
Bit of poly filla on the old blast crater and Bob's your aunties brother.
Old thread but!
Never advisable to drill directly under, over (or even horizontally) from a consumer unit/accessory as they are supposed to be 'safe zones' for installation of cables irrespective of mechanical protection or capping.
Ask the general public what a 'Safe Zone' is and 95% will not know.
Reply to DIY Very Big Bang in the UK Electrical Forum area at ElectriciansForums.net
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
The last couple of de-loops that I have been involved with had the single phase supply replaced with a three phase cutout (as I believe the DNOs...
