DNO charges when needing isolator fitted. | on ElectriciansForums
Guest viewing is limited
Discuss DNO charges when needing isolator fitted. in the UK Electrical Forum area at ElectriciansForums.net
Gavin John Hyde
Patron
Somerset
Spoke to the local DNO this week, as a job im quoting for needs an isolator fitted so i can run a small second CU from a henley block to supply an extension.
I may also be running a supply to the separate garage in the foreseeable future.
I only need them to either de-energise supply and i will fit the DP isolator myself.
Cheeky buggers want over 60 quid plus vat to pull the fuse. Then they will wait if its quick or return to re-energise.
I know we aren't meant to pull them and with modern cutouts its less risky, to be honest i wouldn't want to pull this one it looks old and well sealed with dirt and grime around the edge of the enclosure. far to risky and it looks like its never been pulled.
The prices they charge are as follows(taken from there website)
What do you guys think of the prices? are they pretty much standard across the country?
I was hoping that given the age of the cut out / head they might swap it out, but no such luck they are of view its perfectly fine! then i could have fitted the isolator at the same time.
[ElectriciansForums.net] DNO charges when needing isolator fitted.
Is any part of the DNOs or suppliers equipment unsafe? Loose tails at the meter? Loose tails at the CU?
If you have a dangerous situation, I've found them to be very accommodating in terms of doing it for free.
I have tried that one already, was hoping given age they might replace the head. but they are happy to leave it in place. they sent an engineer out to have a look and he gave things a gentle tug to be sure... seems customer is going to have to pay for the fuse to be pulled.
Shame he couldn't have visited while you were there - he could have pulled the fuse and done his checks while you put the isolator in. They've had to visit twice now and still only got paid one call-out.
Prices seem ridiculous to me. Last month I had British Gas out to de-energise, fit isolator, re-energise. Cost £35 inc VAT
that's a sensible charge. did it include the isolator or was that supplied by you?
That's good. Unusual to hear anything good about BG...
Do you pay anything on a monthly bases so that you can call them out whenever you want?? you know what I'm getting at... (They will come out and fix things straight away as long as you have joined their scheme where you pay £20 a month.... )
Reply to DNO charges when needing isolator fitted. in the UK Electrical Forum area at ElectriciansForums.net
Yes like that - fitted last week 😂
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
