DNO cutout for 1 dwelling with 3 fuses all on same phase | on ElectriciansForums
Discuss DNO cutout for 1 dwelling with 3 fuses all on same phase in the UK Electrical Forum area at ElectriciansForums.net
wwilts
UK
Objective: allow fast charging of EV (22 KW)
DNO cutout has 3 100A fuses, but all 3 turned out to be on the same single phase
How to still obtain 22 kW for fast charging of EVs?
Rotary phase converter? Switched on only when needed?
Other approaches?
The first potential solution is to get a quote from the DNO for a true 3 phase supply.
Are the 3 fuses linked at the cut out from the same single phase supply or is it 3 single phase supplies, all the same phase, coming into the building / cutout and linked elsewhere?
3 single phase supplies all the same phase
Reply to DNO cutout for 1 dwelling with 3 fuses all on same phase in the UK Electrical Forum area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
