DNO Fitting Isolator | on ElectriciansForums
Discuss DNO Fitting Isolator in the UK Electrical Forum area at ElectriciansForums.net
O
omega
Hi, anyone had the pleasure of having the DNO fit an isolator between the cutout and the consumer unit? I'd be grateful to hear of the costs involved
and the amount of time it takes them to sort it. As we all know, only the DNO can pull the bomb so i'm curious as to costs of an isolator. While i'm at it, anyone aware of problems with the smart meters shutting down if the main bomb is pulled, just curious obviously.
Hi,
I had an isolater fitted recently. I was told it would cost ÂŁ110, I said that was too much so they rang back the next day and said ÂŁ65 which I agreed to.
Cant quite remember but I think they came out within a couple of weeks (but only after 2 additional phone calls to push them along a bit and remind them).
This must be a couple of months ago now and no bill so far, so I dont actually think they are going to charge :smiley2:.
This was Western Power Distribution. I expect the service and cost varies greatly depending on the DNO.
Good luck..
don,t be silly archy, the slot your referring to is where scousers poke the wire from a piezo-electric sparker to kill the meter, one "click" meter display and electronics dead free power
theres a circular flush switch built into the front of SOME digital meters
it has a slot
all u need to do is, using a flat bladed screwdriver- turn it counter clockwize to isolate the supply
i have in the past
I was quoted 115 from Scottish power. Although we have a company called iqa that do all of ours in work. Might be worth seeing if u can get an approved subby in who could maybe do it cheaper? Weve Had a lot of problems with the switches tho. Think there abit of an un necessary addition/fire risk IMO. Heard a rumour sp/sse etc are bringing out new meters that incorporate a dp isolator so that we can renew DBS/tails without cutting seals.??
Reply to DNO Fitting Isolator in the UK Electrical Forum area at ElectriciansForums.net
