Hi haptism, either your terminology is incorrect or your understanding of how a DP main switch operates is, if its the latter and like suggested in post 5 - you really need to research the differences between
Main DP switches
Fused switches
Switch fuses
MCCB's (with respect to front end protection)
I recommend you have a think about it before your next post..Ill have to be blunt here in saying if you don't understand the basics of operation of a DP main switch then you really shouldn't be a practising Electrician.
EDIT-
PS - Just to offer an olive branch here and some advice regarding why members have responded as such, your standard DP switch often found on your domestic CU is just that 'a switch' - it is solely for means of isolation and provides no overload or short circuit protection, it will not trip under O/L or S/C conditions.
The rating on the front is solely to indicate the max current it can handle so if the DNO fusing is 80amps then the rating of the DP switch is ample at 100amp.
