DNO fuses | on ElectriciansForums
Discuss DNO fuses in the UK Electrical Forum area at ElectriciansForums.net
G
Guest55
anyone know what the likely breaking capacity and fuse type is for the 250A bs88's the elecy board fit on a commercial supply intake ?
cant check myself on the job i'm at without removing the cut-out chamber cover that has danger of death stickers all over it lol
even i'm not reckless enough to cut the ( very new ) seals on that bad boy :)
Most BS88 fuses of that sort of size will generally be 80KA.
Reply to DNO fuses in the UK Electrical Forum area at ElectriciansForums.net
  • exceeding voltage drop
    The cable is way undersized. If the voltage drop is detrimental to the installation I would make...
  • TT advise
    OK My take on the precautions to implement when omitting an up front RCD on a TT system. Tails...
  • SIL vs ATEX
    Good morning all, I have a question for those who are CompEx and SIL aware - I have various Ex...
