B
bigbaddave
Hi fellow Geordies and Northerners, Northern power grid.. How you rate them?
Has the misfortune to needing there services on a number of occasions and to be fair found them hard work..
Now the latest was, I have landed the tender for a lot of work in the area where a requirement is “ No new rods to be installed, where currant earthing is inadequate conversion to PME must be included in the quote” now a lot are takeing the main earth from the water main, and others have actually had their rod concreted over in the garage with no means of access for inspection however getting ok readings with main bonding disconnected ranging from 30 – 60 Oams.. So the majority will need converting, Well especially the water mains.. May be able to get the concreted one’s in a position in which it can be accessible but if not then although present and showing acceptable reading there not accessible.. How many would be happy with this??
Now after speaking to Northern power grid regardless of quantity the price is ÂŁ156.56 per install.. Has anybody dealt with them. What costs you been quoted?? And is this the going rate?
