DNO says RCD not required | on ElectriciansForums
Discuss DNO says RCD not required in the UK Electrical Forum area at ElectriciansForums.net
Rioja
Cornwall
Greetings to all, first post though been viewing the forum for a while.
By way of introduction, I am a domestic customer and not an electrician in the normal sense - my work involves subsea telecommunication cable systems operating at up to 12kV DC.
Recently got my DNO Western Power Distribution to come and install an isolator (cost about ÂŁ80). When I said to the WPD installer that this was in readiness for a change of consumer unit as there is currently no RCD protection, his response was along the lines of "You don't really need an RCD as we provide a safety earth". I was so shocked (excuse the pun) by his statement that, I'm sorry to say, I didn't question this further. Needless to say, I will be totally ignoring his advice.
I'm guessing he may of been referring to not needing a Main RCD (or volt switch etc) because the system was not (or no longer) TT
Either way the average DNO man is not usually clued up on the 17th edition so I wouldn't worry
Why would your installation require RCD protection in particular?
What makes it so different from the majority of other installations that are supplied with a network earth connection?
I didnt read the info properly thats why in the last post i said it would be down to the installer of the installation not the DNO istallers main switch to be RCD protected if indeed it is needed.
My thinking was, as this is a normal residential property and, I would imagine, the average residential customer would consider a DNO engineer installing a main isolator between the meter and consumer unit to be an "electrician" then what was said would leave the average residential customer thinking to install a consumer unit employing RCD/RCBOs would be a waste of money and offer no additional protection.
Reply to DNO says RCD not required in the UK Electrical Forum area at ElectriciansForums.net
