Hi Folks.
Do all DBs require isolators?, is there a regulation for this?
the reason i'm asking: I'm testing a theatre and they have a series of maintained boards dotted around the theatre supplying lights and sockets. Its a dual supply system, mains and generator. All the boards are the old MEM type with BS88 fuses, where normally, a seperate isolator is fitted. These boards have no isolator, therefore, no local isolation. To isolate a board, you would have to go into the switchroom under the stage and pull out a fuse in the submains board.
can anyone shed a little light on this please.
thanks
thanks
