J
J@mes
I have a customer who has just had a bill land on his mat for ÂŁ16000 in a year - 55000KWH used according to the meter which has jumped from 27000KWH to 82000KWH in the space of a year on the Normal reading, and the LOW reading has seen an increase of around 15000KWH too.
It's on a farm which is quite small (about 5 buildings, 2 barns which contain 1 37KW drying motor and 1 30KW motor) and that's about it.
I've been up there today looking for signs of faults, but there isn't anything. The motors draw the expected current on start up and running, but obviously I haven't been able to do a long term test, other than measuring the currents on each phase for 5 minutes, there is no power usage on the domestic electrics which could be considered to be out of the ordinary either.
The only thing I could suggest to the customer was that the meter was faulty/ out of calibration. The readings are correct as he takes them himself and sends them off, keeping records of them. Normal usage over the course of a year is about 4000KWH, since 2003, up until 2008 where it suddenly jumped up.
Ideas/ Opinions?
Ideas/ Opinions?
