Do I need to separate the earth? | on ElectriciansForums
Discuss Do I need to separate the earth? in the UK Electrical Forum area at ElectriciansForums.net
K
kim_pdx
Can I install a 300mA RCD incomer on a 3 Phase distribution board and still maintain a TN-C-S system? Do I need a separate earth?
You've lost me a bit....the neutral/earth is only combined on the suppliers side, on the consumers side a seperate earth conductor is derived from a terminal at the service head.
Can you explain a bit more.......is it a seperate earth rod you're asking about....agricultural setting etc???
Reply to Do I need to separate the earth? in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Try to keep this nice and short. Had an EICR fail on a health centre due to corrosion on main supply which was causing high Ze values...
I'm assuming the cable will have to be cleated well to hold it in place anyway, as a stuffing gland ain't going to hold it tight like a SWA gland...
