Got my 18th Ed certificate late last year, now doing 2391. Obviously Amendment 2 has come out since then, and I see these courses available to update your 18th accordingly.
But at what point would this be needed? I assume it's not a legal requirement. If I got my 2391 and NVQ in the next year and applied for a gold card, would my 18th cert be classed as not current unless I update it? Thanks.
How can you say your work is safe if you don't even know the up-to-date regs?
e.g. Do you install your cables so that premature collapse in an event of a fire is not an issue?
From your posts I can only assume you don't.
edit: I'm with the opinions above that this is all just a wind up.
I'm guessing you are referring to the metal clips to support the cabling with plastic trunking?
Secondly define if you would please a competent electrician...
Competency is outlined in the wiring regulations.
Competent electrician may be defined in several ways having minor differences, but essentially if you read the entry qualifications to be a member of the Competent persons scheme for the type of electrical work you do, that is typical of the standard used throughout the industry.
Essentially
Level 3 in installation (your C&G will do).
(Including testing)
Current regulations.
Current building regulations where applicable.
Demonstrate to an inspector that your work meets the current standards.
Etc.
Many councils also define this for acceptance of notifiable work from non-scheme members and for inspection work, for example:
submitted in connection with:
• Housing licensing applications under Parts 2 & 3 of ‘The Housing Act 2004’ (Mandatory
HMO, Additional HMO and Selective licensing)
or in compliance with;
• Regulation 3 (1) of ‘The Electrical Safety Standards in the Private Rented sector (England)
Regulations 2020’ (SI 312:2020)
and
• Regulation 7 (3) of ‘The Licensing and Management of Houses in Multiple Occupation
(Additional Provisions) (England) Regulations 2007’ (SI 1903:2007) – as applicable to
‘Section 257 HMOs’,
has / have been produced by a person both qualified and specifically competent to undertake
inspection and testing of fixed electrical installations.
In line with current government guidance, the Local Housing Authority (LHA) may do this by:
1. checking if the inspector is a member of a relevant competent person scheme, via the
‘Registered Competent Person Electrical’ website:
and / or
2. “requiring the inspector to sign a checklist certifying their competence, including their
experience, whether they have adequate insurance and hold a qualification covering
the current version of the wiring regulations and in the periodic inspection, testing and
certification of electrical installations”.
But it covers much more than that, you said your work is safe, so it must be compliant with the regulations.
If you do think your work is acceptable, just do a search on-line for 18th edition test questions.
You should find places where you can take a simulated exam on line for free, you should be able to skip through in 10-15mins (although you would be more careful and take your time in the real exam).
Now, I don't think you would pass as you by your own admission don't have the latest regs, but even without the latest you should be achieving 60%+
Perhaps that will give you a perspective on where you are/need to be.
We just have your posts and words to judge, so that isn't a real representation on your actual level.
@Brian Taylor are you winding us up because quite frankly unless you have been on another planet I find it difficult to believe you are unaware of Part P and its requirements.
Well maybe not in your side of the job but please have some sense of
Competency is outlined in tha wiring regulations.
Essentially
(Including testing)
Etc.
and
‘Section 257 HMOs’,
and / or
Wow you must really like bookwork , but from what you have listed I guess I quality as a Competent person, as I do as you correctly state have a C&G certificate and testing certificate, I do have access to a brown regs book, I have just been informed that one of my co workers has a copy of the building regulations that I can borrow and I'm reasonably confident that I can prove competecy. As for the rest I have no idea or interest in it..I'm far to old to be dragged into the petty buerocacy of local authorities.
I really suggest that you check yourself against an on-line 18th test.
Having access to a book doesn't prove competence
Ah had no idea such question existed...as a matter of interest....is it absolutely required to pay for one of these very expensive regulations update courses or can I simply read the book and do an on line multiple choice paper?
Yes you can do the exam on-line.
You can also just do the exam in a examination facility (usually cheaper) as if you do it at home, someone has to watch you by webcam to ensure you don't cheat.
Sorry I was misled on this one, I don't think they do exam only having re-read it.
Or
Are but two examples.
Before booking, do a free on-line test to see if just the test is suitable for you.
Or
Many thanks
Hi Julie, further to our conversation of yesterday I did find an online test for the 18th edition update...as I understand it you are required to pass just 35 question out of the 60 in the test to pass....I gave it ago ...I think I would of passed....so I guess that an online exam is the best way forward. Many thanks for your help..most helpful....its a shame that some of the others on this site haven't displayed the same humility and helpfulness.
If you do the on-line mock test, it will actually tell you if you would have passed, you can also view your answers to see which you got right and wrong (plus the correct answers).
It's on the third link I posted is it 18thexam or something.
Ah the
one I did required you to pay to give you the results....but did offer access to 1000 questions for about £20 pounds.
Ah the
The link above gives a full on line free test with results, not done it myself but...
OK, just done it, it's a fair to easy representation, I just skipped through it, no book to hand as I just took it out of curiosity.
You should get a result such as this:
You can then go through each question and check your answer vs the correct one.
Essentially
(Including testing)
Etc.
and
‘Section 257 HMOs’,
and / or
It doesn't actually mean they are competent, though.
I wonder what the outcome would be if a scheme registered electrician made the same mistake in wiring a house as the self-taught one.
Should it be like HGV drivers getting a harsher sentence because of them being a professional driver and should know better.
It's the homeowner whose going to end up with the brunt of the load as it's their responsibility.
Been reading the posts, lol many of us dont agree with part p legislation, but its with us and we will continue to have our pants pulled down.
@Brian Taylor having core qualifications is not enough now certainly not in the domestic sector, certain jobs/tasks require notification to building control so joining a scheme cps (competent persons scheme).
Basically you need to be accredited and this is how its achieved by joining these schemes. ££££s
Okay I have trimmed this thread down a bit. Unless you have helpful advice regarding the 18th Ed exam as per @Julie. can you refrain from posting.
Surely the non-notification of jobs is quite a major issue??
Can we all just carry on as we wish in the cheapest way possible then?
Feel free to delete this post, perhaps it doesn't matter.
With no offence intended it sounds as though the OP has been somewhat living under a rock since about Jan 2005. Before that date the manner of working described was common.
There were even signs in the electrical aisle at B&Q about it when it changed so its astonishing if he genuinely has no knowledge of it.
Actually... I'm the OP, this thread was about whether it's worth doing the Amendment 2 if you already have 18th Ed, before it got taken over by a windup merchant.
I can confirm that I don't live under a rock and am aware of the requirements for notifiable work. Cheers!
Yup, I nearly missed that a few times!!
The person to whom the comments were directed, wasn't actually the OP, don't think I made the mistake , but might have.
I haven't re-certified on amd2 either.
I think we will be good until the 19th edition, which at the rate we get changes imposed, will be next week!
I think it's always going to be of benefit if only to show towards being competent, especially if the worst happened, and you ended up in court.
Agree, and I've now done the online Amendment 2 course, even though it was pretty steep at £90. I now have a certificate to prove that at least I tried to understand all that is required of me.
It is a matter of life and death after all.
And there you go, thats how easy it is yo do the right thing. Nice professional attitude.
Norfolk
United Kingdom
Do I need to update my 18th edition for Amendment 2 ?
UK
Ventricular Fibrillation,
MJPD29,
