Do these wire caps need to be removed prior to installation? | Page 2 | on ElectriciansForums
Discuss Do these wire caps need to be removed prior to installation? in the UK Electrical Forum area at ElectriciansForums.net
Manchester
I am installing a new electric hob, the wiring came with these cable caps at each end. Its a single phase installation so I'll be combining L1 & L2 at the junction box. Do these cable caps (silver colour) need to be removed? See picture.
I assume so, but if you could confirm it would be grateful. They are also on the end that is pre-wired to the hob.
[ElectriciansForums.net] Do these wire caps need to be removed prior to installation?
I would mate, but then all the girls on here would be after me.... even more than they are now....:tearsofjoy:
Yeah right????? First day with Age UK as a handy person, unpaid, just doing mybit for the aged, or as Tel says age is just a number, my Mrs reckons a lot of these widows may be after a new Man, boosted my ego no end, with all the pratling on about good looks, you should give it a try!!!!!:):eek::oops:o_O
I’m quite surprised at the responses on this thread, the OP has asked a reasonable question and showed that he has a good idea of how to connect this for single phase use.
It’s not unreasonable to ask about the ferrules as their use is not always common knowledge within the trade, let alone among DIYers.
Pictures please Spoon, don't be shy
I reverse searched via this website using an algorithm that I wrote in my spare time a tracer to pick up IP addresses where I then could attach code to the packet streams to allow me to access users devices, I managed to access Spoon's computer and found my way to his holiday snaps photo album, well I won't give too much away but the Police have been informed but I did find out that he tells fibs.........
Spoon on holiday,
Spoon on holiday,
I've always liked that pic.... my hour glass figure.....
I bet you'd swap spit with me @SWD...
I don’t know what is more dangerous - the dress or the Luger, actually the makeup has a risk all of its own!
Reply to Do these wire caps need to be removed prior to installation? in the UK Electrical Forum area at ElectriciansForums.net
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
It's difficult to see what wire goes where in your first pic, but I'm assuming the new green/yellow connects to a wire that goes to the earth pin...
