Do you know what make & model this is? | on ElectriciansForums
Discuss Do you know what make & model this is? in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
I don't suppose anyone knows what make and model this heating controller is do they?
the customer has just sent me the photo, I plan to swap it for a Honeywell 7 day programmer but need to know which way its wired really.
Thanks to anyone who knows!
[ElectriciansForums.net] Do you know what make & model this is?
Hi,
If you take the programmer off it will more than likely have a wiring diagram on the back.
It's a two channel programmer, just replace it with a 2 channel programmer. The only thing that could be a little funky is if it's a gravity system, but then you just flip the switch on the back/move the jumper.
I do t really touch heating controls, so you are going to have to explain how I know if it's a gravity system.
I wouldn't worry about it to much. Take the programmer off and look at the back. If it doesn't have a diagram it will have a make/model you can google.
most programmers with industry standard back plates are like this.
  • [ElectriciansForums.net] Do you know what make & model this is?
If turning the CH cannot be turned on without the DHW being on then it is gravity.
In a gravity system the DHW channel on the programmer fires the boiler, the heat then gravitates through the pipework to heat the cylinder. The CH channel switches the supply to the roomstat which then operates a pump to circulate water in the heating pipes. Thus to have heating on the hot water must be be on.
The gravity setting on a programmer will prevent CH being switched on without DHW being on.
Other clues to a gravity system are the lack of any motorised valves or cylinder stat, an ancient boiler, 28mm (or bigger) pipes to the coil.
Any particular reason you want Honeywell?
If not I'd recommend Drayton over Honeywell. We'd normally fit an LP522 (5 day/2day, 2 channel) as standard or an LP722 (7 day, 2 channel) if the customer really wants 7 day control.
The vast majority of people just want the 5/2day option so that they have one set of times for weekdays and another for weekends.
Reply to Do you know what make & model this is? in the UK Electrical Forum area at ElectriciansForums.net
Interesting item you have there. This blog might be worth a read https://sllipblog.wordpress.com/2014/04/29/its-now-00-28am-and-i-need-my-bed/...
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
