Do you need to be an electrician to change a light bulb? | on ElectriciansForums
Discuss Do you need to be an electrician to change a light bulb? in the Australia area at ElectriciansForums.net
O
OFS
I work for a company that manages properties while the home owner is away on holiday. Then while the home owner is away the property is rented out. If a light bulb blows we will go in and replace it. If replacing the bulb does not work, we call out an electrician to fault find. Do you need any special accreditations or certificates in the UK as an individual to change a light bulb in someone else’s property?
If you don't already, the way this country is going, you can bet your boots that before long you probably will and you'll need a certificate of competence before you can pick a hammer up !!! :(
Only if you pay ÂŁ500+ per year for the privilege. Oh, and once a year someone will come around and watch you do it.
Reply to Do you need to be an electrician to change a light bulb? in the Australia area at ElectriciansForums.net
All it needs is the existing lampholder replacing with a suitable new E27 lamp holder connected directly to the incoming cable, replacing/...
My experience with commercial lighting is when the fixture is ordered or bought the specs should say 120/277. Then their wiring diagram should be...
