Dodgy trade pictures for your amusement! - 1 Million Views! | Page 467 | on ElectriciansForums
Darkwood
Enclosed within the rose and accessible. While not the most elegant of solutions, were any regulations breached?
If one were to be ultra-pedantic (not that any of us ever do that of course) then the bit arrowed should be sleeved with LED tape lights that alternate between brown and red.
Doo-doo-doo-doo..... The twilight zone!
Where messages just disappear!
One of those days when i wish i'd taken a photo.
Old fluorescent in a kitchen to take down.... Had a red into live, another red into neutral and 2 x normal sleeved cpc.
Up into the attic to see what was going on.... The 2 reds were from 2 x 3core & earth, the yellows connected together, the blues connected together... not in a box.
2 way switching.
Its getting rewired anyway, so will not be staying like this.
No, it was a neutral. Light worked fine.
L&N feed to one 2way switch. L to common, Y and B of the 3 core to L1 and L2.
Y and B linked through at light to other switch, Red coming back from second switch stops at light as switch wire, other red from first switch is neutral from light back to feed neutral.
Thicko's don't know how to get to a fuse terminal in an old MEM Exel DB.
RFC needed isolating.
Three phase supply installed, by them, from right hand side fuses but had to do a bit of circuit shuffling. RFC moved to top left to accommodate. All red fuse guards broken off to get at the terms.
Obviously incapable of working out how to remove them.
No sign of any alterations to schedule.
PS. Not the first time I've come across this, by the way.
Manager says we had a pir on one of the cottages and Sparky man says that the sub main hasn't an isolator, can you sort one out.
It's fed from here, another cottage next door.
A pair of 16mm t&e feeds 2 cottages from the henleys.
urmmmm i think it needs a bit more than an isolator.
Ho do ou remove those fuse guards? only ones I have seen like that pull straight out or they are held in by a clip and a ph1 screw
What's wrong?.....looks like there's been an NIC domestic installer involved, all is rosy.
You’ll never be short of a Henley block after sorting that lot.
