Dodgy trade pictures for your amusement! - 1 Million Views! | Page 491 | on ElectriciansForums
Darkwood
I once had SSEN tell me that a property I was at wasn’t 3ph. Despite that fact that I was staring at a 3ph service head, 3 lives and a neutral coming out and a 3ph meter with a CU on each phase. When they eventually did send someone out as 2 of the phases had no power, they agreed it was 3ph. Then they found damage to 2 of the phases at the transformer. 🙄
Not all '3Ph' heads have 3 phase supplies. I know of several, including one of my own, with 230V with respect to neutral, on two of the fuses, but with 460V between them, and I know of one where two of the fuses are live, but are both connected to the same single phase.
We have just had another supply put in, 2 phase, no earth connection supplied.
Phoned Dno to see if they would allow TN, they refused connection, which doesn't make sense as all the other cottages are Tn.
A real pain for me as there are a few sub-mains battery-solar, cottage, stable, workshop and a large bio mass system.
That isn't an argument cpcs connect initially to the accessory.
You could over extend the cpc and loop it through the lug to the accessory so initially connecting to the back box first but would have thought is fine.
Only other thing I can think is they never connected one as there’s quite a decent solar and battery setup (in terms of generation and storage) so maybe they did it to go full island mode and not rely on the distributor earth. But that’s just a pluck out of thin air guess.
To run in island mode (or any other backup power supply) requires you to have your own means of earthing, but that can be in addition to any DNO earth.
Obviously supply has to be disconnected in such modes!
I guess it might have been a TT system before the new cutout was installed and so the DNO simply left it?
No I didn’t as it hasn’t ever had one connected. So didn’t touch anything on the cutout.
I’ll be back there in August as they want a circuit running for aircon. So will have a look then. But odd that the DNO didn’t mention it was available. They just said their records show it’s TT. 🤷🏼‍♂️
With a TNCS the supplier never connects a main earth conductor, that's down to us - they provide the terminal only.
I'd be tempted to arrange a quick visit from the seal fairy and have a little peek inside to see if there's a N-E link or one piece N & E block. I'd bet there is. :)
I'm back in Aug anyway to do an Aircon circuit for them, so will have a look then. Just need to chat with the seal fairy...
I'm the fall guy again. We do a fair bit of work for a property company, insurance work and such like and they have a few different teams as they are quite busy. I get a phone call "can I pop round to a job in the morning (done by the other team), the joiner cant find the cables for two heaters and handover is at the end of the day, spark broke his leg apparently
Bear with me, this will be a long one.
sodding electratech system, not messed with one for years. (my wagos trying to make sense of it.
First problem, newly decorated flat with 2 storage heaters removed for the renovation (flood I think) still all in one piece and full of bricks, they now look like they have been dropped out of a 1st floor window. No spur, and no cable so its saw time.
Nice live wires in the wall, certainly at night anyway.
Dismantle them ,try and straighten them out, re fit them an power them up only for the manager to say we cant leave them in I'll get two new panel heaters.
Then we find the towel radiator for the bathroom still in the bedroom, again no power, no outlet for it and its broke. (no pictures but I had to wire a new supply for a new towel rad as well so more holes) and convert to 24hr power etc.
Next up as I'd messed around with the electratech system I thought I'd make sure the hot water still works for when they move back in. Couldn't get power to the two immersions no matter what I did so removed one of the switches.
Apart from the fact the earth is in the neutral terminal where are the immersion cables, snipped off and curled up in the loft, that's where. more problems.
Shower lid.
As well as a badly fitting lid, new 6mm supply and no RCD, no RCD for new hob supply either.
Not over yet - finds out the fridge socket is dead, I suspect it is the old kitchen storage heater supply but I cant get it powered up no matter what I do so I have to wire a new one. Take the kitchen plinth off to see if I can fish it anywhere without more damage and find this.
I sort of gave up at that point, couldn't reach it to do anything with it, job was 40 miles from home and everyone else had already gone back home so I just put the plinth back and convinced myself I'd never seen it.
Not sure what had gone wrong with that job really, was the spark that bad or have the other trades screwed him over, they do like to mess with stuff they shouldn't. I dread to think what else there is in that tiny 1 bed bungalow.
What I did in the end was what I could, no chance of getting merlin stuff on a friday afternoon so I had to fly to toolstatioin and buy a couple of garage units and pinch the RCD's MCB's out of them. I managed to at least make it safe(ish) if not compliant, I ditched the electratech system altogether, there wasn't a control panel for it in the flat anywhere anyway, probbly been snipped off and binned.
I've saved the best until last as well (no picture unfortunately) Bearing in mind all this work, complete property renovation, client put in hotel etc was all caused by a water leak, and when I was in the loft messing with the immersions there was a bit of water dripping from the tank area, the 20mm overflow pipe from the cistern tank hadn't been glued into the elbow and it had fallen off. Tradesmen, you just cant get a decent one anymore.
I can only guess that while his back was turned, the other trades just did what suited them.
At a previous job, amongst other stuff I did the internal networking. The builders were a right p.i.t.a. One time I'd removed a twin network socket from a wall that was coming down, coiled the cable up neatly, and tucked it away on top of a purlin where it couldn't come to any harm. Couple of days later I walk pst and notice it's been pulled from the purlin, dropped in a tangle on the floor, and something's been dropped that's fully cut one of the cables.
Any time anything of mine was in the way they'd just shift it - never so much as a "by the way, we had to move ...", I just find stuff not where I left it. There was one occasion when I was really tempted to borrow a big sledge from maintenance - it's not like the joiner couldn't have left my cables sat neatly in the purlin when he fitted the window recess, but oh no, they all had to be pulled out and left dangling like washing lines.
And I won't describe the state my Gilbows were in when I finally found them after the roofers had been using them for a while :-(
... the 20mm overflow pipe from the cistern tank hadn't been glued into the elbow and it had fallen off. Tradesmen, you just cant get a decent one anymore.
Plumbers, don't you just love 'em.
We have a rental flat, with another above. Tenant told us that there was water dripping from kitchen ceiling - so I go upstairs and inform the owner, he says he'll call out his plumber. His plumber says there's no leak he can find.
Water still dripping from our ceiling, so go and see chap upstairs who lets me have a look - a few seconds later I've found the leak (from the cold water connection to the WC ballcock). OK, it wasn't an obvious leak, as in visibly dripping, as the water was running down the pipe and disappearing into the boxed off bit hiding all the pipes. So leave him to call his useless plumber out again to fix it. But, the delays have meant that our kitchen ceiling is now sagging.
Roll forward a bit, chap upstairs rings me (while I'm on holiday elsewhere in the country) asking if I know where his stop tap is - which as it happens I did from when I'd been looking into the previous leak. No idea if I could blame his plumber, but the chap was watching TV when he heard a bang and water was gushing out from under his kitchen units. Turned out one of the flexibles to the taps had failed - no idea if it was pipe failure or not connected properly. So that's the end of half of our kitchen ceiling which we pull down so it doesn't fall down when it feels like it.
So when the tenant moves out (moving onwards and upwards) we get the kitchen ceiling replaced, as well as applying multiple coats of paint to cover the water marks in other rooms.
Roll forward a couple of months, water dripping from ceiling again. Chap upstairs gets his plumber out - who can't find a leak. Plumber asks me if he can make a hole in our bathroom ceiling (where the bulk of the water is coming through this time) and I agree a small hole "say, an inch or so" for him to put a camera through.
So, what do I find when the tenant tells me the water hasn't stopped ? He's left the fan dangling on it's cable, partially dismantled the ducting, and cut a hole about a foot square in the ceiling and left it. The **** told me that the water wasn't coming from upstairs, it was coming in through the fan ducting - despite the fan ducting being dry, and the concrete blocks ABOVE it being wet. Yes, a plumber who believes in water flowing uphill on it's own.
Upstairs to see the neighbour again - we do actually get on alright. For some unrelated reason he has the bath panel off, and with a torch and mirror I can see up the box and see a pipe going drip ... drip ... drip.
So that's the new kitchen ceiling with water marks, a gaping hole in the bathroom ceiling, and water marks across the living room ceiling.
I sometimes get asked if I know a tradesman for something or other. As I tend to do most work myself I don't really know what any of the locals are like - apart from the handful of plumbers I wouldn't trust to change a tap washer without supervision.
