DOE supply loadings, maximum demand | on ElectriciansForums
Discuss DOE supply loadings, maximum demand in the Australia area at ElectriciansForums.net
Dusty
Hi All,
I have a three story house to wire, with the following floor areas:
Lower ground: 144 square meters
Basement: 157 square meters
Upper floor: 94 square meters
Apart from lighting circuits and cctv, electronic gates, kitchen circuit which is of course additional
I would find the boards existing supply of 20 KVA single phase, not up for the job and would consider a three phase supply requirement, given the 17th edition regs.
Anybody else agree with this ?:confused:
Is it a single dwelling ?
Who is going to pay for that 3 phase supply it could cost thousands
20kva is approx 87 amps so I'm assuming your DNO fuse is an 80amp. Rather than the 3 phase route which is very rare in a single dweling I would look at the posibilty of the DNO upgrading that 80amp to 100amp.
Unless there is going to be a huge demand load, the with Diversity 100amp in a domestic situation should be plenty.
Shukran sedeke,(thank you my friend)
Thanks for the info, money would not be an object for my client, (He works in Saudia as well ). But i quite agree as to the cost implications.
I dont know if you read Arabic so I put the translation in .
I wil go with this option
Dusty
Reply to DOE supply loadings, maximum demand in the Australia area at ElectriciansForums.net
