Does an external socket outlet need notifying | on ElectriciansForums
Discuss Does an external socket outlet need notifying in the Australia area at ElectriciansForums.net
I'd be grateful for some advice on the following. I am planning to install an external socket outlet on the outside wall of the kitchen, i was going to run a fused spur from the ring main (there is an existing internal socket in just the right place), however, the building regs state that "adding socket-outlets and fused spurs to existing ring or radial circuits is required to be notified to Building Control". I presume the same rules apply if the socket is going to be external?
Thanks for any help
Down2earth (halfway through domestic installer course)
Reply to Does an external socket outlet need notifying in the Australia area at ElectriciansForums.net
Why aren't you asking them?
An example of the long term race to the bottom of quality of work in our industry, IMHO.
