does any one have pat test software i can copy | on ElectriciansForums
Discuss does any one have pat test software i can copy in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
E
electromotive
Does anyone know where i can get free down load software i have the seaward europa?
so i can down load my results.
thanks:20:
wouldn't recommend copying any software at all, if you get found out you will get the high jump....try looking for cheap (genuine) software on ebay, there's companies that sell things on there for PAT testing...
Be careful what operating system you''re using will determine what level of Patguard you would need.
Offset the cost when you do you tax return.
seaward europa originally came with a CD containing the software to download the data..
It was 9 pin serial connection.
no longer have the CD but maybe seaward could supply one.
Reply to does any one have pat test software i can copy in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Thanks for that suggestion for SELECT's virtual course, though I rather think it would be better to send him on an in-person course to get better...
