Hello, I am an Electronics Technician, was my original training and trade (over 5 years of training and College/Uni).....as well as work..
Right, well first thing is that Rosin Flux is now out of general sale as far as I know, so no problem there, and all solder is now Lead free so you cant even buy that anymore, no worries there (all new solder is a combination of Tin, Silver and a tiny percentage of Copper...)
You dont need a vaccum rework station kit as this is primarily intended for reworking solder on surface mounted IC chips (intigrated circuits) and the hot Air workstations are intended for Ball mounted IC chips (such as Graphics processors and Audio Digital signal processors) on things like motherboards and graphics/sound cards...
What would be ideal for you for doing repairs/replacements is :-
1) a 25Watt Small tip Soldering Iron (Antex Soldering irons-the yellow ones are very very good) about 20 pounds.
2) De- Soldering Braid in various different thicknesses, this is for soaking up (removing) old solder and leaves a very clean removal of solder..... the good brands are Antex, Nimrod and Multicore Brands. about 4 pounds a roll.
Watch how you hold this as it heats up VERY FAST and can give you a BURN if not careful.
3) A desoldering hand pump as a standby for any large puddles of solder (which is rare) about 10 pounds for a good one.
4) A soldering Iron Stand (about 5 pounds)
5)A solder heat resistant mat (about 15 pounds)
6) a few pairs of good safety spectacles/ safety Glasses.
7) Some Solder - Multicore is one of the best Brands out there, they do various different thicknesses (and purposes) of solder and I keep a good variety of them myself in my kit... also Antex do solder, and Multicore do a Tip Cleaning dish with cleaning compound in it.
8) a Desk lamp
9) a few sets of heat dissipative tweezers
10) good variety of small and medium philips and slotted screwdrivers..
11) an OLD and Clean Rag/Cloth which you should keep wet, for cleaning the soldering iron tip, this is much easier and better than those little sponges that are provided (do not use a kitchen or shower sponge, it will melt and put off fumes)
12) Open a window and set yourself up in front of it AND/OR get yourself a small extractor fan set up that goes out through the wall or window if you are going to do soldering regularly..
DONT leave the Soldering Iron switched on when you are not using it as it will be a fire risk and be VERY CAREFUL as it can BURN you very easily...
Keep your safety Spectacles/Safety Glasses on when using a soldering iron or other heat source at ALL TIMES as Solder can bubble and pop and may splash into your eyes which you do not want to happen...
Be careful and have a good day soldering......I hear the going rate for replacing a Laptop power Jack connector these days is between 60 pounds and 75 pounds....LOL
