B
Bobster
Ok, so I'll put in a little background.
On nearly all the sites I look after, the overloads for just about all the smaller >75Kw motors are in a main panel in each sites main switch room. Not a problem until something trips out, it's usually operator error, overloading conveyors etc...
Now the operatives aren't allowed inside the panels (for good reason), and due to the fact most of the small satellite sites they won't have an electrician there so this causes undue downtime.
On all the new installations I've used Telemech gear, for which you can get electronic remote reset devices that clip to the overload like this:
LAD703 - Remote stop or electrical reset device for LRD up to 30 kW - Documents & Downloads
This enables a push button to be mounted outside the panel that the operatives can reset themselves (following a set out SOP)
Now I'm wondering if moeller produce a similar peice of kit I've tried twice today to get through to their tech support and not had any luck, and have spent hours looking online searching and not found anything. Most of the satellite sites use moeller's Dil range overloads so if they don't produce one that will fit their gear it looks like I'll have to start replacing them slowly over the upcoming months. (As long as my budget stretches lol...)
