L
lofty84
state measures to provide protection from live parts of terminations?
would you say this is asking me about protective equipotential bonding and automatic disconection of supply ie joing all exposed extraneous conductive parts within the istallation together
or am I headeing in the wrong direction ?​
Im not 100% sure but I think it could mean the following..........
* Insulation of live parts.
* Barriers or enclosures.
* Obstacles.
* Placing out of reach.
I got that info from 'The schedule of Inspections'.
cheers guys.
state the Ip codes apporpriate for the top and sides of an electrical enclosure.
does anyone know where I might find this info in the bs7671 as I cant seem to find it. I have the on site guide to if its in there again I cant find it
thanks
IPX4 and IPX2 im guessing.
Im eating my tea, will confirm that in a bit if no one else turns up with a definative answer.
okay....
got muddled up there dyslexically....
The answer is...
IP4X on top of the fitting.
IP2X on sides, front and bottom of the fitting.
Someones had a bad day.......
Smile.
Im fairly positive about the IP2X and IP4X ratings.
Im not accustomed with IPXXD or IPXXB. But as your day has been awful Howard I will just agree with you. Im sure your correct.
Grin.
thanks very much guys I think I might need to tab this book up ?
the next thing I am trying to look up is the difference between IPX4 and IPXXD but its not proveing to friuitfull at the minute
the additional letters are in BS EN 60529
A: Protected against access with the back of the hand
B: Protected against access with a finger
C: Protected against access with a tool
D: Protected against access with a wire
the IP4X gives protection against solid objects greater than 1mm from entering the enclosure and 1mm wires from contact with live parts inside the enclosure
the IPXXD is just protection against 1mm wires
Does anyone know what this is asking me
Australia
lofty84,
brucelee,
