I'm buying a house and have received the electrical testing certificate. There were two C1's and a C2 identified, all very easy fixes even for an amateur DIYer, the problem I have is that the electrics were condemned for this reason and so the busbar was removed from the consumer unit. This also seems a very simple task that I'd happily undertake but I just need to know wether this kind of work would need to be undertaken and signed off by a professional or the implications of not getting it done professionally if any...I've attached some pictures of the faults which as I said are very cheap and easy fixes and don't really warrant the call out and first hour charge of a professional if I can get away with it.
- TL;DR
- If an amateur is able to fix C1 faults easily, can they also reinstall a busbar that is removed as electrics condemned for the C1 faults? Or does this need to be signed off?
