Does Ring Transformer Need Fuse? | on ElectriciansForums
Discuss Does Ring Transformer Need Fuse? in the DIY Electrical Advice area at ElectriciansForums.net
philcox
Kent
Hi,
I have recently installed a Ring Pro Doorbell. It has come with a transformer which is going to be connected to the lighting circuit as the CU is too far away.
My question is, does it need a Fused Switch on the supply or can it be powered straight from the lighting circuit?
Personally I would put a fused switch next to it so you have a point of local isolation.
Reply to Does Ring Transformer Need Fuse? in the DIY Electrical Advice area at ElectriciansForums.net
Hi, How did you install your doorbell in the end?
If it's going to be an emergency stop and not just a stop, then other factors come into play depending on what sort of machines the emergency stop...
