Does this look ok?? | on ElectriciansForums
  • Thread starter whazza22
  • Start date
  • Replies 6
  • Views 1K
Discuss Does this look ok?? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
why are you feeding the switch? They normally want you to just simply add an intermediate in to convert a normal two-way switch circuit and if you are using t+e/3+e then you just put the intermediate in between the switches to swap the L1 and L2 lines when it's switched. Shouldn't need lots of choc blocks.:eek:
Upvote 0
Reply to Does this look ok?? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
There is no homework, and I'll never see these photo again.
Electrical Courses
