Does this work need a certificate? | on ElectriciansForums
Discuss Does this work need a certificate? in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
I replace about 30 lights from 2D to led, I'm under this impression I don't need to issue a certificate for this as it's only maintenance, am I wrong because the company are now chasing for a certificate
Many thanks
Take a look at chapter 63. You can use a minor works for change of current using equipment. That’s assuming you’ve changed the light fittings.
You are not wrong as it is like for like. However it is sage to at least offer a minor works and test Zs etc. I replaced 600 x 600 fluors for LED and found 89v on the earth just doing routine testing. Always wise to check imo.
Hi all,
Many thanks
I would issue a minor works certificate for each circuit worked on.
Reply to Does this work need a certificate? in the UK Electrical Forum area at ElectriciansForums.net
They have done electrical work... they should test it before anyone else gets a chance to alter it. In fact... here it is from the BBB "641.1...
It applies to commercial if it shares the same supply as a dwelling.
