doing 2394/2395 need help | on ElectriciansForums
Discuss doing 2394/2395 need help in the UK Electrical Forum area at ElectriciansForums.net
like stantheman said, those reports really helped me pass this time (failed in december)
you need to digest GN3 as they only want the answers from that book, not wot you already know or a mate said. i failed to put enough detail into my answers and assumed they would already know the circuit was isolated before testing, well that didnt help. its impossible to tell you wot to expect, just go over GN3 but make notes each time you do, i find re writing it as i read it helps it go in??!!
as it says in those chief examiners reports, try to allow enough time for the larger pointed questions, and dont sit dwelling on a 2 pointer, for ages. say 15 mins for 15 points, 2 mins for 2.
good luck mate
dont fall into the trap of doing loads of 2391 past papers it has totally changed there is no easy way to pass anymore , as said GN3 and on site guide , i sat my 2394 a few months back not had results yet but i dont think i passed as i focused on testing to much when studying for it and the test was more to do with inspection , good luck
just passed the 2395 couple weeks ago , only "difficult" part is the written just read up on GN3 and the regs book , past 2391 papers are available but be aware 2395 is periodic and 2391 and both initial verification and periodic so be carefull dont get wrapped up in the wrong Q's
Reply to doing 2394/2395 need help in the UK Electrical Forum area at ElectriciansForums.net
Hello guys, need your helps now, my question is how do you call this thing on a HV relay protection cabinet in English? it enable/disable a...
FFS - popped it apart, found the same issue and thought I'd update... You guys were already there!
