So tell me. What is SO different wiring an American home 110v; 220v most texas homes with the British home? Rocket science???? You all think im a college pal never touched a wire before or dont know the different wires to use in a circuit? You all make me laugh.
BS7671 will be what you work too here, in the States I imagine they have there own version which will be nothing like ours.
Now that is the difference.
In that case why don't you come clean as to what these other qualifications are and what level of experience you have?
Anybody can come on too an open electrical forum spouting conflicting information but the facts remain you have either got it or you haven't so lay your cards on the table then you may get some serious advice.
Ok then, tell us the necessary steps in properly designing a domestic electrical installation since you know so much about it. You can then tell us how to go about inspecting and testing it to make sure it is safe to energise. Perhaps you could tell us why the test procedure is in the order that it is, after energising what tests are then required and why.
There you go, some nice easy questions to start you off considering you're so au fait with "pretty much wiring a house"
I don't need to prove myself. I only came here to know the legal requirements before doing work in this country. As I got the answers I needed: get the bs 7671 which seems to be the uk standard of things and other regulatory body etc
Yes I do sounded like I don't know Jack but that's how I speak :) When I'm home ill get back to the other questions.
some jumping to conclusions on this thread. partly the OP's fault for not giving any info on what/if his US qualifications are. must remember that americans are reluctant to give out info. reds under the bed and all that.
The basic principle of electricity flowing from A to B through a cable may be the same but the regs are massively different and much stricter in the UK. This is what you need to learn via various courses. Theres a lot more to it than knowing what cables to use for each circuit.
Have a read of this:
Description of Part P and its requirements.
Can you imagine if we went and started working in France or the USA I bet they wouldn't allow it!
I have my full lvl 3, took 4 years training then working on the tools for another 2 years after i was qualified just for the experience and to learn tricks of the trades, 2 years out on my own and only now i would class my self as experienced.
Im new to these forums myself and this was the 1st thread i seen. I agree with adamroche144, i served a 4yr apprenticeship and have been qualified now for nearly 10 years. I too would say that only recently i would refer to myself as experienced. OP IMO is either a bad troll or dangerous guy.
As others have stated, your by no means an electrician, and no means experienced! You can pretty much wire a house and you think you can call yourself an experience electrician? You are a joke!
I think there is a certain amount of stuff that can be done safely by unqualified people these days, as long as they have reasonable skills and a high level of common sense - such as changing a switch or a socket, maybe a light fitting or a fan. However I have had to do an NICEIC course to prove my competence to do just that....Accessory Changing......It now takes 15mins to change a socket and loop/polarity test and then 45 mins to complete a MWC. However house rewires - anyone that attempts it is nuts.
Many householders think exactly that, then when you get called in because something isn't working, you find that they simply "thought" they knew what they were doing. A little knowledge... and all that.
Doing work without a qualification
Business Related
thereballer,
Guitarist,
