Discuss dol starter overload calculation? in the Electrician Talk | All Countries area at ElectriciansForums.net
Its 3 phase so formula is:
I = kW / ( √3 x pf x VLL ), in kA
For 3 phase Kw to Amps without power factor I divide the Kw rating by 0.692 - the result is in Amps. 0.72A in this case.
what we used to do was run the motor/pump at full load and then tong the cables. then set the starter 10% above that.
Reply to dol starter overload calculation? in the Electrician Talk | All Countries area at ElectriciansForums.net
