H
Discuss DOL starter problem in the Commercial Electrical Advice area at ElectriciansForums.net
What purpose are you putting this to... what measures are you taking to ensure the auto start up is not a risk to anyone in the area or even maintenance personal.
Using a pulse start timer is not always as simple as it initially seems, if you require it to drop out the contactor then you require a N/C channel that is not affected by the timer when it call for 'ON' ... and vice versa basically a 2 channel pulsed timer with independant channel timers.
You could have the time clock act as a retaining latch but this then gives the timer priority on the stop circuit which won't be allowed ...
You need to tell us exactly what its controlling to give you a accurate response.
The DOL starter is controlling a feeding system for pigs and there is a N/C paddle switch on the last mail bin to cut motor off when bins are full but I want this timeclock to bring on feeding system first thing in the morning
So what happens if an intermediate bin runs empty while the last bin is still full? Do they have slide gates?
I’ve put a fair number of bunker feed systems in, you’re going to need a little more than the starter and a relay.
Reply to DOL starter problem in the Commercial Electrical Advice area at ElectriciansForums.net
