Dol starter | on ElectriciansForums
Discuss Dol starter in the UK Electrical Forum area at ElectriciansForums.net
Ch1
Norwich
Hey guys posted a simular thread earlier regarding a dol starter, anyways popped down to check it out tonight, everything's seems to be ok, iv tested the nc and no terminals and etc etc, issue is you press the stop button and it takes a split second to stop. Should it not be an instant stop, functional stop switch.
I assumed it should be instant but takes a second to stop... thoughts please... anyone had this issue?
All starters will vary with regards to the travel distance of the stop button motion before it disrupts the contacts. If you are using excessive force to operate it then you could say there is a problem.
Reply to Dol starter in the UK Electrical Forum area at ElectriciansForums.net
