Domestic 3 phase or Single | on ElectriciansForums
Discuss Domestic 3 phase or Single in the Domestic Electrician Forum area at ElectriciansForums.net
P
poppypiesdad
Eve pub members , would you if you had the opportunity do your own house in single or three phase , starting the build and organising the services I need , and there is no difference in cost for the single or three phase , bungalow , 3 bed , air source heat pump in single or three phase.
What would you do ...
Jamie
Reply to Domestic 3 phase or Single in the Domestic Electrician Forum area at ElectriciansForums.net
Given that a lot of EV's only charge from one phase when connected to a 3 phase chargepoint does the customer really need a 3 phase chargepoint...
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
