P
Piratepete
Hi Guys
Magnet is refurbing a kitchen.
The client wants all switches out of sight (in cupboards) which Magnet has agreed to. Their electrician has installed a cable (concealed under plaster) for the cooker hood vertically from ceiling to a point below the working surface where I guess it will be connected to an FCU.
How does this comply with the requirement for the zone to be visible ie. in line with an accessory e.g. FCU or socket? Does the cooker hood count as an accessory?
If this is OK, can I run the cooker supply cable (which is my responsibility), the same way, in line with the cooker!!?
Cheers!
Pete
Cheers!
Pete
