Domestic cooker | on ElectriciansForums
Discuss Domestic cooker in the Domestic Electrician Forum area at ElectriciansForums.net
keniff
east sussex
About to use one of those double outlets for oven and hob igniter just wondering what everyone's views are on connecting hob igniter straight in on the outlet plate as there is no way of over loading the hob cable. I normally fuse down with spur but this outlet plate looks handy and can both be isolated on the cooker switch!
I;m guessing that you ar erefering to the clic one.
If the hob just needs an ignition I prefer to put it on a 13A socket.
if you use a dual outlet connection box, you can fit a CCU one side and a 1363 socket to the other. then fuse plug top down to 3A or 5A. ssimplesss.
Reply to Domestic cooker in the Domestic Electrician Forum area at ElectriciansForums.net
A MCB serves as an isolator (Table 537.4) so unless specifically requires DP a MCB will suffice.
I recall where a fluorescent capacitor would cause a separate socket RCD to trip when turning off the light
