Domestic fuse boards | on ElectriciansForums
Discuss Domestic fuse boards in the Domestic Electrician Forum area at ElectriciansForums.net
T
trigger1973
Hi, I'd like some advice on the fuse board in my house please?
It's quite an old house and the fuses are sited on a wooden board. We have been recently discussing renting the house but a friend of mine said we would have to upgrade the fuse panel in order to rent the property so that the tenants are fully protected against any electrical fault. So my question is, is that true, will we need to upgrade? And secondly, if we decide not to rent the house, are we obligated to upgrade the panel for ourselves? Is this expensive, i realise that all things are relative but how much would someone expect to charge for upgrading a fuse panel to adhere to current regs?
Finally, I'd be interested to know where I can read about such regulations, can anyone tell me where to look please?
Thanks,
Dave
if you are not renting the property, nobody can force you to upgrade, but wooden based fuseboards are a fire risk, also for your own safety, it is recommended that the board be replaced, with a unit complying to current regulations.
a qualified electrician doing this job would inspect and test the wiring to ensure that it was safe with no faults before undertaking the fuseboard upgrade , and would then be able to advise you of the cost involved in fitting a new Consumer Unit + any other essential works to make the installation safe, finally completing an Electrical Installation Certificate.
Difficult question to answer as it will depend on where you live and what else may need to be done to bring the installation upto the required standard, for example main bonding, tails and any problems that may exist on the installation, the most obvius being neutral to earth faults which will be picked up by the RCD's
My area basic CU change with tails £350ish but your best course of action is to get in some local sparks to give you a quote. Put up your area and there are probably guys on here that will be close.
Hi trigger, as above basically. I am based in the Midlands so £350.00 not a bad starting point for a board upgrade.
Thing is how big is the property? If you intend to let it out to multiple occupants (HMO) you may need to install smoke detection systems.
A little more info please, as as a (prospective) landlord you will have a duty of care to your tenants. For instance in-laws have a guest hose of 10+ rooms which must have a suitable fire alarm system.
Regards wa
I rent out a house locally, when I approached the estate agents i was told the situation is this:-If you are managing the property yourself then then you require Absolutly nothing but your normal legal obligation as a landlord to keep the property electrically safe and maintained in a good condition.However if you are letting the estate agents manage the property then you will require a Periodic Inspection Report or the new Electrical Installation Condition ReportYou do not need to change the fuse board just because it is old, it could be as safe as the day it was installed.My advice is a EICR or PIR from a competent and reputable electrician, then he will use his experience and skill to give you a judgment on your overall installation
Keep seeing this in the threads on the Forum!! And was thinking, ....how many of those wooden framed fuse boards have been installed?? It must have been in the multi millions, from back in the middle 50's, and how many have actually caught fire over all these years, i bet not even 1% of them!! There must be countless millions of them still in use across the UK to this day too... I know that i personally, have never seen or heard of a single one of them catching fire, and certainly not as the source of a larger fire...
Funny really, as i know of quite a few, let's say modern plastic CU, melting down to a blob of liquid plastic on the floor, taking the plastic MCBs etc with it...lol!!!
Reply to Domestic fuse boards in the Domestic Electrician Forum area at ElectriciansForums.net
Youre in the same boat as me. I was previously with niceic and later on, napit. No issues. I didn't bother finishing my nvq3 as in 2010 during the...
This looks like a decent project to get your teeth into. It may be worth your while looking through the directory on here for your area as your...
It's quite usual for the mods to delete a reply/post if its too an old thread, happens to me often 🥴 they then notify me and tell me not to answer...
6K
