P
Paul 1962
We live in a 1960's terrace. The electric supply is via a fuse box with old school rewireable fuses and the system is fine for our needs. There are no children or pets to consider in this scenario.For plastering and decorating purposes, the door and attached frame was removed from the wall by unscrewing the four screws holding the frame in place. In essence the wires, fuses, etc. are now in a recess in the wall. The frame will go back into the space.Do the regs state that the door must be metal? I was thinking that it would look so much better if the 'hole' could have a lightweight removable mirror/picture/painting over the 'hole' rather than the frame containing the door which sits about 2" proud of he wall when in place.Safety is important but common sense also works and I would appreciate all qualified comments. Many thanks, Paul
