R
rsmck
Hi,
I'm installing a 14 way Hager CU with a terminal rail supplied as standard with two neutral terminal bars and a larger earth terminal bar, the housing is helpfully marked with numbering.
As I am installing three MCBs which will not be RCD protected I have an additional 5 way terminal bar to which I will terminate the neutrals for the non-RCD circuits. Obviously by adding this the manufacturer-fitted terminal bars must be unclipped and moved further along, meaning the markings and numbering no longer correlate properly with what's actually there.
Looking for a bit of advice (not replaced a CU since the 17th edition and extra RCD requirements etc were introduced) as to how I should mark this - should I place my own (correct) labelling above the terminals or simply rely on the fact that it'll be blatantly obvious the pile of green/yellow sheathed cable in the middle is clearly not a neutral
Supplied from factory;
What i'll end up with is as follows;
Long story short - I'm only really concerned about the 'right' way to label this, the somewhat lengthy post just (hopefully) proves I've thought about it!
Thanks again - this site is proving invaluable
14way N | 17way Earth | 10way N |
14way N (5 used) | 17way Earth | 10way N (4 used) | 5way N (3 used) |
