Domestic Installers Course | on ElectriciansForums
Discuss Domestic Installers Course in the Domestic Electrician Forum area at ElectriciansForums.net
stephen1974
I've just seen that the level 2 domestic installers course is no longer recognised as of March 2011.
Is this correct? and if so, how long have people been aware of this?
I've spent ÂŁ7000 on a course that will give me this and ifs its already no bloody use im going to insulation test someones genitals. :mad:
it's being replaced by a level 3 qualification instead. you can still register for the level 2 qual up to end dec 2011.are you aware that the only actual qualification you need to join elecsa's part p scheme is 17th ed regs. you only need to be able to demonstrate ability to test and inspect on the assessment day.
Reply to Domestic Installers Course in the Domestic Electrician Forum area at ElectriciansForums.net
You’ll need level 3 qualifications- 2391 or equivalent plus 18th edition to get on an PV course. To join a scheme and sign work off, I think...
