domestic lighting wiring and switching | on ElectriciansForums
Discuss domestic lighting wiring and switching in the Domestic Electrician Forum area at ElectriciansForums.net
T
tawraste
hi everyone,
got another query, this time about domestic lighting wiring and switching.
it seems to me that from a design point of view this is one of the most diverse areas in a domestic installation.
i've noticed on forum threads the borrowed neutral of old, i've noticed in my own home the method of wiring to the switch first, and i've noticed in friends' and family's homes new colours with multi-core cables. then there's the sheer variety of switching. my mates new extension has a separate new circuit for the lights going straight to a four way switch, one of which is part of a two way on the other side of the room of which the security light is also connected. the wiring arrangement looks baffling !
having looked through all my books there's no details about switching design. so i looked for some software, no dice.
in the end i took other forum members advice and drew the circuits in their various switching positions.
i have to say this has helped a great deal.
however, i would still like to find a resource that covers this area. can anyone recommend a book? or anything else?
i think it would be useful to cover this area fully with a bunch of switches on a board run off a couple of batteries. also such a resource would help with identifying old switching designs such as the borrowed neutral. there's a site called flameport which has excellent guides for getting to know the old accessories - but again, very little about the actual switching and wiring.
absolutely any advice orhelp would be greatly appreciated,
many thanks
tawraste
dont know if any book exists at the end of the day a switch is just a switch so it would be a short book.
make a mock board with a plug on then you can try any combinations you like and see how it works.
you tend to learn one way and two way switching at college but they tend not to cover older wiring versions such as borrowed lives, neutrals etc, with a couple of lights and few swirches and some diagrams you will soon figure it out though
Reply to domestic lighting wiring and switching in the Domestic Electrician Forum area at ElectriciansForums.net
thank you it really made me feel small, maybe i played it a bit thick, but as the one needing the work done i was cap in hand, will try another...
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
