B
babba
I was wondering if a house is being renovated with no heating at the moment and you install pv before the heating goes in
do you need an EPC to apply for FITS 21p rate.
Discuss Domestic property no heating at the moment, EPC in the Domestic Electrician Forum area at ElectriciansForums.net
wouldn't work, a house has to be heated to be habitable (unless it's genuinely a passive house), so the EPC assessor would assume portable electric appliances would be used in each room, so it wouldn't get a D rating.the EPc ask for number of rooms ?
then number of heated habitable rooms which would be 0
our EPC assessor has done thousands of EPC's and has stated that habitable rooms with no heating must be assumed to be heated by portable electric heaters, so not being funny, but I think he probably knows his way around EPC's a little better than you.your wrong Gavin on this one
if you look at epc software or epc survey sheets
no. of rooms?
no. of habitable rooms?
no. of heated habitable rooms?
habitable means where you can sit or sleep .
so if you can not fit a table and chairs in your kitchen its classed as not habitable !
I am a newly qualifed DEA & EMCK accredited I am still learning but confident I am correct .
you can not assume on a epc either .....
Reply to Domestic property no heating at the moment, EPC in the Domestic Electrician Forum area at ElectriciansForums.net
