Domestic Query | on ElectriciansForums
Discuss Domestic Query in the Domestic Electrician Forum area at ElectriciansForums.net
M
MR_ELECTRICIAN
garage getting converted to a kitchen, best way of doing it? 6mm t+e from original cu on a 32amp mcb , up the wall in trunking thru the loft to garage (garage connected to house) to a 4 way board, mains switch 32amp radial for sockets 4mm, 6amp radial for lights. Is this ok?
Sub board for a kitchen ? Not the way I would ever choose to do things. What's the reason for this ?
You have had the benefit of seeing the job so surely you are best placed to choose the best way to do this job ?
Probably but not the way I would do it, I would come from the down stairs lighting circuits for the lights, put a new ring in for the kitchen ring and as mentioned by aesmith cooker supply?
No mate he's asking us how to do it
What to do is wire it that way then get the customer to run the cooker, the microwave, the toaster and the washing machine at the same time and ask if they are happy with your workmanship!! Absolutely no clue!!
I find myself replying to less and less as the days go on in this place. rules say that if we can't be helpful then don't bother. that's my excuse for staying schtum so frequently.
says a lot about the quality of posts here these days...
Dan is this helpful enough
Reply to Domestic Query in the Domestic Electrician Forum area at ElectriciansForums.net
I would put this down to 433.3.1(ii) - no overload protection needed because the load at the single socket can't overload the cable, being fused...
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
