N
nottm9550
Hi All,
I Have a keen interest in Electrics and wish to pursue a career in this field. I have completed my part p, 17th Edition and also my 2391. I am no electrician I know that however oneday i hope I will be.
My self and girlfried are decorating and i have replace the exsisting dimmer with a switch. I have also replaced 3 wall lights.
Since completing this work a fault has presented its self in the form of: not all the lights work together. They all have power flowing to the however the readings are 230V and the other 2 show between 50-120V and not enough to illuminate all 3 together.
Obviously with the lack of experience i have i am unsure what the issue could be. My thoughts are as follows. The dimmer was masking the fault as i know the dimmer starts/stops the flow allowing it to dim and not giving it the full current. would there be a chance that the line and neutral have been incorrectly wired up thus sending the feed back down the neutral and receiving a feedback current?
Any thoughts and advice would be welcomed. Id like to sort this issue myself as a learning curve, thoughts and advice would be greatly appreciated.
Steve
Steve
