G
Gixxerdan
I have just recently bought my first house and have took all the carpets up and stripped all the walls for redecorating so I am looking at the wiring in the house to see if there are any problems. In the bedroom there are 4 double sockets and 1 single socket but only a couple work. The light fitting does not work either (there are 5/6 bulbs so unless they have all blown, which is unlikely, there is a problem somewhere) My first instinct about the sockets is that there is a loose connection somewhere. If I wanted to chase where a socket was fed from, is there a way to do this by testing rather than literally pulling the cable out and tracing it? Also is there a way of finding out which socket is first on the ring main? I have voltage testers and a multimeter so is there a way of finding out using either of these??
Thanks,
Dan
Thanks,
Dan
