Door bell volts drop? | on ElectriciansForums
Discuss Door bell volts drop? in the UK Electrical Forum area at ElectriciansForums.net
This one is doing my head in.
installed a 12v transformer. Ran 3 pair telephone cable to an underdone bell and through to a press switch (not illuminated). maybe 20 metres in all.
connect it all up and .... Nothing?
Getting 12v on the output of the trannie and 12 v at the bell.
disconnect the circuit going to the push. Now it's just a 6m run from the bell straight to the trannie. getting a slight trembling at the bell.
Take the bell off and connect it through a metre of cable to the trannie and it's fine.
i've changed the trannie and doubled up on the telephone cable cores, but still nothing. Am I missing something?
Is the transformer big enough to run the bell ?
The dome bells are not usually true circular and the strength of trembling can be changed by adjusting the orientation of the of the dome if its not set up right it wont reach at all....
Thanks all.
i've installed hundreds of these on domestic jobs, but this is a shop where they want to call from the till to get people through from the back shop.
while I was getting 12v at the bell, my multi-meter is on another job and I was using my voltage tester and assumed it wouldn't show 12v without it being there.
on reflection, 20 metres is probably a bit far for the trannie to push, but there just isn't an alternative - shorter - route. I might try using a 12v trannie and test the voltage to make sure it won't burn out the bell - assuming it will push 8-12v over the distance.
Thanks, Phil. Tuning bells has been the bane of my life at time - especially working on your own and running back and forward. But the bell isn't getting enough to kick the striker at all. I think it has to be volts drop; I ran the cables myself and installed a new trannie, push and bell.
Cheers for that, Ed.
The problem is it's such a daft situation: The original 12v trannie was located about 3m from the push in one direction, and about 5m from the bell in another. But the original bell wire was fed under the floor. I can't get access to the floor, so all I can do is run around the perimeter walls from Trannie, to Bell, to Push - and I guess the 12v trannie just isn't up to it. I've ordered an 8-12-24v unit which will - i hope - do the trick.
Reply to Door bell volts drop? in the UK Electrical Forum area at ElectriciansForums.net
Just doing some thread admin :)
