M
markh2k2
Im a sparky and Iv been asked to look at a door entry system, which I do not have to much knowledge about. I have found that that everything works apart from it will not ring inside the apartment when called from the outside. I have also been told that there is similar problems with other apartments at the same complex. The handset is a 2 wire Bticino 344342, the system is around 7 years old. Has anyone come across the same problem, do you think it could be the handset?
