Door Entry System problems | on ElectriciansForums
Discuss Door Entry System problems in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
B
brizospark
Installing a door entry system, had everything wired up and connected however the magnet seems to be extremely weak and can open the door no problem.
Checked voltage at the magnet, 12 V which is correct - any ideas?
could be voltage or the plate isnt marrying up to the lock correctly,take the plate off the door and put over lock,if you cant budge it its a position problem.
thanks alarm man I tried the magnet straight onto the plate and the magnet was solid. It was my numpty of a colleague who fitted the position of the magnet and I suspected that this may have been the problem. He tried several times to reposition but still could not get it to hold, could hear the magnet buzzing
sometimes its just that the plate is too tight on the door,it should have a bit of play,videx is quality kit,so it will be something simple to put right.
Reply to Door Entry System problems in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
M
Shower door frame installation? Hi, We're currently adding an en-suite to a downstairs bedroom, everything is going well so far, BUT, ive...
Monster
M
