Door entry systems | on ElectriciansForums
Discuss Door entry systems in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
N
Newsome3
Anyone do these? The type that are in flats etc?
Much money in them worth doing?
Not done any before but thinking about learning to do them to add another feather to my cap so to speak
Cheers
worth doing mate, another string to your bow.fairly easy, do bit of research on what your fitting and av it in your head what to do.its all work that u must take if its there,an with the money that all comes down to how long will it take,how are u gettin wires from a to b etc
I recently got into it also, part of an ongoing factory refurb I have been involved with.
I fitted a Targha BPT with 3 handsets and a maglock. That then led on to them wanting CCTV at the door and inside the warehouse, will be going back to add a fourth handset in another location.
Having not done one before, I did a mock-up at home so I was not scratching my head on site trying to work it out, it looked as if I knew what I was doing!
Reply to Door entry systems in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
As it was explained to me, you can write anything in the book so long as it already exists in the book somewhere in original print. Tabs, etc are...
