Dopey First Post | on ElectriciansForums
Discuss Dopey First Post in the Australia area at ElectriciansForums.net
G
gbrad
Apologise for my ignorance but I'm really new to this game, just recently passed my Part P and 17th.
Anyway I'll get to the point, my missus has gone out and bought a cheap flush fit bathroom light from B&Q for me to swap over.
Took the old one down, straightforward block connector inside it. The new one is where I've got the problem, it doesnt have and connector block, but 2 push in connectors at the back of the lampholder. Havent used one of these before, wanted to know whether to use chokblok and use singles from that into the back of the lampholder as the push connectors look pretty small and I cant see me fitting the existing wires into them. I don't have much cable to play with either so it would be a stretch.
Probably the most basic post in a good while but I havent come across this type of fitting before and I want to make sure I get it right cos I'm sure I'll come across it again.
Probably easier to go buy the fitting myself too next time and get something decent!
ah i see the problem straight away!!!
as detailed below
1) as you described "missus" buying stuff (serious problem)
2) B&Q (not as bad as point 1 but still bad)
3) you say you have done 17th and part P and you don't know how to fit a Light...!! (Massive problem)
im sorry if it feels like im having a dig on point 3
Ok any ways back to the post, why not get some twin and earth and strip it back from the sheath and give your self some "singles" joint them in to chock block that is attached already and then join the "extended cables" in to the push connectors, they probably good for upto 1.5mm solid cable.
steve
curiosity...!! you got a link for the new light from the B&Q site...???
Where you intending to "stick" the chok box?
Hopefully NOT up in the ceiling :eek: unprotected
or
NOT in the actual lamp fitting, if it's the type of lamp I think your talking about you might have a problem with heat.
Jim
if it goes in to ceiling i would follow it "via loft" and install a JB or
Click Flow 16 Amp Push-in Connector
nice little nifty piece of kit!!
or just a standard
Chocbox Connector Cover
not sure what light he on about so cant comment on heat etc!!
Good point your on about an approved "chocbox" think gbrad was just talking about connector block. And probably a bit of that electricians tape people think we use for everything.
Can't you sleep Mr Durham Spark... You didn't have the miss fortune of going to the same dodgy indian as me tonight?
[ElectriciansForums.net] Dopey First Post
Jim
well now you mention
no mate i never had indian but i did have a bad gut all night, and a very very close call with the WET fart!!! had to remove boxers as they got damp!! :( mixed to gether with other fluid that should have been SOLID was not very pleasant experience!!
was night shifty buddie im a Elec Maintenance Engineer !! i work two jobs as im mad!! the domestic spark is just an enterprise i set up as a bit of fun (expensive) and eventually i hope to grow it..!
what curry you have..... chicken , lamb, beef, dog, cat...?? RAT!!!
Jim
Its funny you should say that, i dont think i have ever used insulation tape to insulate anything. i mainly use it for taping things together and for identification purps
Are you still alive? How did it go?
Not sure he is...
May be we need a new obituaries section for 5day wonders that have past away
Jim
Please help, I am gas safe trained and I cannot get this solder to fit underneath the fitting, I have pushed really hard but it just wont go under....
Thats coz you need the Gas on when soldering!!
Jim
Reply to Dopey First Post in the Australia area at ElectriciansForums.net
Thought I'd update this. Finally had my assessment today. I chased them on Friday morning as it'd been about 10-12 weeks since I'd actually made a...
And if it's a garage then use metal clad accessories.
