Double Insulated tool question?????????????????????????? | on ElectriciansForums
Discuss Double Insulated tool question?????????????????????????? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
P
phatspanner
Hi there,
New to this forum so hopefully someone can help! Working at the moment with 110v angle grinders in an industrial setting. Had a read of the instructions for the grinders we are using and it says;
" Avoid body contact with earthed or grounded surfaces, such as pipes, radiators, ranges and refrigerators. There is a risk of electric shock if your body is earthed or grounded "
Problem is, I am working on a structure that is earthed for lightening, is it dangerous for me to use the grinder?? I will am working either in contact with the structure or in very close proximity of the steel (less that 100mm)
Any help is appreciated as I don't get paid enough to get zapped!
Mart
That sounds like a Chineese grinder.
The clue is in the title "Double insulated"
Most 110v angle grinders are used around steelwork perfectly safely.
Reply to Double Insulated tool question?????????????????????????? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
